Stand back she's ready to blow!
Old 05-31-2013, 07:33 PM
Chevy_King1500's Avatar
just went out and checked mine and it has the insulation around the dryer. 02' truck
Old 05-31-2013, 07:38 PM
Truck Sponsor
TrickTurbo's Avatar
Need to put some insulation there. That's pretty warm.
Use header wrap if you have some left.
Surprised your ac still works right. If the tank is that hot wonder what your low side psi is.
Point the laser at fire wall and other things in the area. See if they are as hot.
Also all plastic or rubber in the area is probably start melting.
Old 05-31-2013, 07:43 PM
Gadgetized's Avatar
The overflow tank might have to go. The front reservoir is engine coolant, and middle is intercooler coolant. The front reservoir occasionally gets hot, and I dont want that heat transferred to my intercooler coolant. I dont have meth in the tank yet. Not sure if I really want to with that much heat around it anyways .
Old 05-31-2013, 08:44 PM
I have a gauge for that
Atomic's Avatar
Keep in mind how those infared thermometers work...you could be seeing some reflected radiation off the downpipe. The more reflective the surface the less accurate those thermometers are. Im not saying its not hot, but take that number with a grain of salt. If you have a contact thermometer that would be even better.
Old 05-31-2013, 08:48 PM
Gadgetized's Avatar
Good point. I am sort of new to using it. I might do a little more testing with it tomorrow. Im still going to look into sending the DP to Swain Technologies to have coated.
Old 06-01-2013, 07:01 PM
Gadgetized's Avatar
Tks Richard, it was reflecting off of the drier. I covered the DP with cardboard after a drive and the drier was 150 degrees. I worry too much.
Old 06-01-2013, 07:23 PM
Alpinestar's Avatar
Atomic breaking out the science behind gadgets...
It still wouldn't hurt to shield the dryer if you don't end up sending the DP to get coated. But if you do get it coated, you might post up some before/after temp numbers.
Old 06-01-2013, 07:53 PM
14psisupra's Avatar
Seen a few of these threads recently. What size dp are you guys running. I haven't had any problems with mine in over a year. Dp is just wraped with some header wrap
Old 06-01-2013, 10:34 PM
holley2346's Avatar
Wow i never had wrap on my downpipe and never had insulation on my a/c stuff. Always worked great... Melted the hose coming off one time so I added a turbo blanket. But other than that had the kit installed for over a year with no issues.
TX Tahoe Z71
09-01-2015 09:11 PM
atxlt
07-20-2015 11:06 PM
rojeho
07-12-2015 06:10 PM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: Stand back she's ready to blow!
