stock 6.0 @12psi
Old 09-21-2009, 06:26 PM
Mort's Avatar
Do you have a BOV? It is important with a manual trans to help keep the turbo spinning higher during shifts.
Old 09-24-2009, 05:25 PM
sowaidi's Avatar
i do have a bov, i dont know if the 60-1 turbo is small for the lq4 to not make it boost, but in some runs it does hit 12 psi as how i set it on the controller, i know im loosing torque with a smaller turbo but it boosts better with the manual tranny.
Old 09-24-2009, 05:37 PM
11 Second Club
Phantom's Avatar
my 5.3 made right at 500 at 12psi...front mount with 02 ls6 cam w/112lsa and meth
Old 09-26-2009, 07:32 AM
Mort's Avatar
I used to make 12 psi all the time with an A4 running a 60-1. The difference is that the A4 keeps the turbo loaded during shifts and the boost stays up. I even get a bit of a boost spike during shifts.
Old 09-26-2009, 08:19 AM
05crew's Avatar
what number should be expected from a stock lq4+cam @12 psi w/sts?
my stock 6.0 lq9 in the denali at 10psi ran 7.75, with a 1.74 60s, then a week later i poped a piston..lol
Old 09-26-2009, 03:35 PM
9 Second Truck Club
stock48's Avatar
thanks man, im using the 60-1 turbo since it does alright with the t56 which needs to spool more than the autos. i would guess id go down on torrque. but im aiming at something like that.
You will be WAY out of the range for that turbo on a 6.0L @12psi. A 70mm turbo would be good at 10~12psi and be ok with the stock pistons if your tune is spot on.
Old 09-27-2009, 09:46 AM
t_thall's Avatar
Originally Posted by 03 BLACKOUTSSS
I am surprised no one has mentioned the potential for forced removal of the piston top from the rest of the piston, but I may be underestimating these pistons.
I've ran mine at 13.5psi from time to time with lots of meth, no broken pistons yet, I wouldn't run it there too often though!
Old 09-27-2009, 07:30 PM
i ran my cammed lq9 to 12psi with a pt70gts, estimated 646 to the ground, (AWD), truck went 12.27 @ 111 rolling out not on boost, so far so good on the motor, knock knock, motors on borrowed time at that level though. Truck weighs 6000 lbs with me in it!
Old 09-27-2009, 09:24 PM
How do I change this text
Wilde Racing's Avatar
60-1 is a bit small. although I've ran one...
greedygenius
09-03-2015 06:51 AM
05GMC4.8
08-07-2015 09:55 PM
OLD BULL
08-01-2015 05:00 PM
steves86ta
07-28-2015 10:21 AM
Suburban2500
07-19-2015 04:50 PM
Quick Reply: stock 6.0 @12psi
