Stock 6l80 vs stock 4l80
Is the 4l80 stronger then the 6l80 in stock form? I have been running my stock 6l80 for a couple years at 12psi and it's on its way out. Thinking of swapping to a 4l80 if they are stronger already. I don't see any reason to spend big money on a built 4l80 if it lasts me a few years the way I drive. Also what is needed to convert? Thanks for any help.
What hp and torque are you pushing? What's the future look like?
I have never put it on a dyno so no telling. Engine is hurt so I'm going to put a stock 5.3 with triple 12 cam and twin turbos. I can see myself pushing to 600-700 hp. I know the 4l80 has superior aftermarket support but just in stock form wondering if it is stronger. If not I won't go through the time and expense of converting. I'll slap another 6l80 in it. Every transmission builder just recommends there top of the line transmission and I think that is way overkill if the factory 6 made it this long.
I just had mine built. They basically converted it to a 6l90, added clutches and made valve body upgrades. It skip shifts super fast now and will go from 6th locked to 3 in about a tenth of a second. Seems to handle the power better so far, I have about 4K miles on it so far and I like it. Converter choice was a bitch bc I still tow with my truck, so I went with a closer to stock stall single disk billet unit. I would build my 6l80 and roll on, the parts are out there to fix issues now and so is the knowledge...
Shop local to me that used to build my Allison's for my diesels.
