stock map? When to get 2 bar?
Old 04-10-2008, 01:05 PM
SpoolinChevy's Avatar
I'm not too savvy on it either. I believe if you buy the 2bar, then you get it tuned for SD.
Old 04-11-2008, 05:37 PM
bpope's Avatar
Hmm...well my stock MAF is maxed out...I wonder if I should go to 2 Bar? Obviously my tuner has compensated for this as it hasn't blown up yet.
Old 04-11-2008, 06:27 PM
nonnieselman's Avatar
Originally Posted by kbracing96
Stock on the left 2 bar on the right
Thats the picture ive been lookin for!!!!!
Old 04-11-2008, 08:58 PM
Sleeper04's Avatar
That is correct.
You can still stay with the MAF as you said you tuner can still compensate for it. However, SD is much smoother and more accurate since it is adding fuel based on boost rather than "guessing" how much fuel to add through the MAF table.
Old 04-12-2008, 01:56 PM
bpope's Avatar
Originally Posted by Sleeper04
That is correct.
Good info man. Yeah, I can see now where it would be a smoother power curve. Thanks for the info. Is SD easily affected by differing weather conditions?
Old 04-18-2008, 02:34 PM
Banned
dmoss69's Avatar
Default Thanks!!!
Thanks fellas, I just ordered my 2 bar sensor!
Now is someone has a MAP table they want to share to get a base line, that would be great also! I'm running tunercat, so just a copy/paste table would be good, I have to transfer all the numbers one at the time anyway.
I have the 6.0 liter.
D Moss
Old 04-23-2008, 08:08 PM
D Moss
I use EFI Live
C6301 is the MAP Sensor Scaler
The MAP doesnt have a table but It has a Parameter that needs to be changed.
Stock 1Bar map = 94.4 (look around till you find this number i guess?)
2 Bar = 190
3 Bar = 288
Old 04-23-2008, 08:11 PM
Old 04-23-2008, 11:00 PM
Banned
dmoss69's Avatar
Default tunercat
Yeah, tunercat is different.
From what I've been reading, the voltage still stays the same on the sensor, so we just divide the tables by .5
ie...
100kpa = atmospheric on old map sensor
50kpa= atmospheric on new 2 bar map sensor
Don't hold me to it, but I think that's what is going on. I haven't got my sensor yet, not sure what the hold up is. Seems everything I order from scoggins-dickey that I don't pay that outragious shipping cost's on takes twice as long to get here than from everywhere else. It'll be my last thing ordered from them too.
Once I get the sensor, I'll double check it with real world data, and go from there.
DM69
Old 04-24-2008, 12:14 AM
MFIC's Avatar
For the 2bar map with HP Tuners
Map Sensor Linear 200.00kpa
Map Sensor Offset 10.33
chopperloco
07-10-2016 10:45 PM
Ketis
07-23-2015 12:37 PM
GMCtrk
07-17-2015 06:39 PM
jrplz
07-09-2015 12:07 AM
Quick Reply: stock map? When to get 2 bar?
