Stock Truck Map Sensor for Boost Tuning (SD Tune)
#22
Sure, if he scaled it.
I maxed out a stock maf on 10psi with a 5.3...I didnt want to bother with scaling so I just went straight 2bar sd on that setup and its been great. If everything is tuned properly you will not notice a difference in table resolution between the 2 and 3 bar. Hell I ran NA for a while on a 3bar sensor. The lower resolution is not that big of a deal.
#24
Aem Air Inlet Intake Temperature Temp Sensor Kit AIT | eBay
#27
This is true but he is spraying 3 meth nozzles and using e85 or race gas for safety. Jarrett is also doing his own tuning so he can make adjustments on the fly. I guess the pixie dust is magic that won't work with a 2 bar sensor.
#30
Can any recommend one over the other from the point of better tuning and idle characteristic. I mean GM 3-bar vs GM Dmax 3.3 bar map sensors.
