sts is on!!!!!
sts is on!!!!!
just got my truck back for the shop and it has good power! meth is not on yet but is coming soon. im seeing 6-7 psi in 1 and 2nd gear, but when it hits 3rd it jumps to 10-11. is this normal? thanks for all the help over the past week or so!!
I AM A MOTHERF*CKER
i have a boost controller it is a *** up under the right rear finder. i need to turn it down, but will that change the boost i 1st and 2nd gear? do i need a digital boost controller?
it depends on what spring is in there. if you have a 5lb spring and turn the boost controller all the way down you will have 5lbs tops and if you already get 5 psi in first then you will still see 5 psi in first. i would turn the boost controlle all the way down and run it to see where you stand on just the spring. then turn it up a hair at a time and run it between each turn to see what it does. and stop when ou get to the level you want to kep it at.
Maybe an 8 pound spring?
Mine has a 3 PSI spring, no boost controller yet. WOT it will get as high as 6-6.5 psi. My guess is the wastegate is not big enough to keep the boost down to 3....but I don't really know.
I'm hoping the boost controller will go in this weekend (along with TR6's).
Speaking of which, everyone enjoy the long weekend!!
ZO6Ted
08-12-2015 07:50 PM
chris99gmc
17
12-04-2004 05:50 PM
