STS Bulletin about oil blow by....LONG...
#21
Originally Posted by 8ALTNG
The funny thing is with mine is I dont have a PCV and I still spray some oil ????
I want to know how all this excess pressure builds up in the crankcase in the first place??m Is this just from pumping loss out the combustion chambers or some type of leak?? Or just normal.
Is this just a boosted motor thing, or does it happen in high perf high compression engines too?
#22
#23
Mort~ I have the both places running to my catch can with a breather on it. I can see the steamy stuff coming out of the breather at idle and when I let off the throttle. I do not have a problem with crank pressure. Has anyone taped into their oil pans with this kit?? If so can you send me or post a pic of it. thanks.
#24
Nice, looks like its time to ditch the solenoid valve and PCV. I just don't know how exactly I'm going to keep the pressure switch for the oil pump. I'll probably just tap it off the intake manifold where the PCV used to be.
#25
I plan to put the check valve in the line to the manifold from the PCV Valve and leave my PCV system operational for now.
#26
11 sec. Truck Mod
well, i found out that i had the ground wire to the manifold bolt instead of the switch valve. my mistake, now it works well. doubkle check your ground wire guys!its easty to think that cause its a ground wire that you should "ground "it to metal, but its already grounded and "grounds the switch valve that is mounted to the plastic manifold. i guess its an easy mistake to make.
#28
there is just too much extra stuff going on with the STS kits. To many electronic things to go wrong IMO. I want to install a kit and be able to forget about it, or drive from Maine to Texas without worry of something like faulty extra PCV or oil return pump going out. I'm just not that trusting I guess.LOL
#29
I guess this is one reason I'm glad that when I bought my kit slightly used, it DIDN'T come with instructions. I had to figure out how it all worked on my own. I figured out that the ground wire there WAS for the solenoid, and is connected to the system ground that attaches to the fire wall.
FWIW, I have never had any problems with my PVC valve or anything blowing oil out. But I did have a problem with the pump blowing fuses when I was in WY this winter. Apparently, the oil pump doesn't like to pump cold oil in low speed when it is below 0* outside Just jumpered it to run in high speed all the time when it was really cold out and havn't had any problems since .
#30
