STS exhaust suggestions
Originally Posted by spinz71
Whatever you use, make it big! What happened with mine is that it created boost creep. The exhaust is a restriction and it will cause backpressure all the way back up. I have an 8psi spring but with the exhaust I get 10 psi. I have a 3.5 inch dynomax race (straight thru) welded to the turbine exhaust pipe and dumped over the axle.
Ogkevin, Hows that hideaway intercooler workin out?
I'll admit I'm not sure how it works. What I do know is that I had the about 10-12 inches of straight pipe after the turbo and was at 8 psi. I put on 21 inches of 3.5in. muffler and a turndown and it went to 10 psi. Nothing was else changed. I can't imagine that being less restrictive. But this truck is so weird it doesn't surprise me.
I had a 3" in/outlet dynomax rv bullet muffler on the sy. It was quiet at part throttle and roared at WOT. Lack of b/p causes boost spike/creep and excessive b/p can also cause it too. (had a magnacharger with a 8psi pulley see 12psi with a 2 into 1 muffler.)
Lowering backpressure downstream of the turbocharger increases the effective expansion ratio across the turbine, resulting in higher turbine efficiency / more turbine output power for the same massflow and temperature.
This will generate more boost if your wastegate / boost controller is not functioning properly, as the turbine can drive the compressor harder.
First post on here - work with this stuff for a living, thought I'd chime in.
- Matt
- Matt
no muffler
http://youtube.com/watch?v=N0IztgcOi24...
check out this link... this is my cady.. I run 3 inch exhaust straight thru... 3 inch after into a 5 inch diesel tip... it makes it echo.. sounds absolutely amazing.. no muffler, still have the cats
