STS Guys with no cats, what mufflers are you running??
Ok, so I have searched and come up with a little bit of info, but I know how you some guys like to change mufflers and stuff
, so I though I would ask what all your setups are. Pics would be nice and where the muffler is located (before or after the turbo).
I just put on a catless y-pipe from jegs, which is a nice piece BTW, fit perfect, now it's just too loud and raspy and has a lot of resenation around 65-70. I'd like to put the muffler before the turbo as I am in love with the whistle and don't want to lose it
. I'm thinking of going with a Hooker Aerochamber, but can't decide if 1 3" would be enough flow. Which hooker would you suggest, a max flow or aerochamber? What do you guys think?
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
I AM A MOTHERF*CKER
Don't put the muffler before the turbo -- you want as much exhaust pulse hitting the turbine as possible (which is why to ditch the cats
). You won't loose the whistle.
On my 6.0L I ran a flowmaster single chamber race muffler (series 10) and the resonance could be annoying. With the 408 it was ridiculous
and after the little roadrage incident, I changed over to a 3" dynomax camaro setup (where the spare tire used to live) for daily driver days and a cutout for go-fast days.
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
![Burnout](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_burnout.gif)
Yeah, I used a split flow muffler. It got the sound down alittle. It's only 6 inches long and 5 inches tall. It was all I could fit behind the turbo. I thought about doing the camero set up. But just put this on, I am happy with it. Everyone loves the sound, I still think it's alittle lound still.
![Cool](https://www.performancetrucks.net/forums/images/icons/icon6.gif)
I put a 14" Flo-Pro dual 2.5" in/single 2.5"out in front of the turbo. The sound is a lot quieter but not as mild as stock. It took away a lot of the low speed resonance and popping sound that I used to get under light throttle loads and it is a lot quieter in the cab. I did a G-Tech run after the install and saw a .10 improvement in my time. I still have the cats installed because I hear the 6L is really loud without the cats.
Originally Posted by greentahoe
Do you have a link for the Y pipe? Is it a direct fit for stock manifolds? Is it 2 1/2 like the stock Y or is it 3"? Wish I could help with the muffler thing, but for now Im going muffler less and doing a 3" to 4" reducer and some 4" pipe out the back.
![](http://i3.photobucket.com/albums/y57/Kbracing96/Dynopics002.jpg)
Thanks for the input guys. I'm thinking I'm going to go with a muffler after the turbo and maybe a cutout, but there's just not much room there, cuz I don't want to loose my spare as I travel a lot in this truck and I want to keep the stock look. And Damn, are these thing loud without cats
This is the one I got Y-pipe It was a direct replacement for my truck. Fit great to the stock manifolds and was $200 shipped. It is 2 1/2", but if you want to use the rear O2's, you will have to move the right rear back about 2-3 inches. They f-up on that one. It does come with 4 plugs for them if you don't want to run any O2's though.
. I even have a full stock tail pipe and it still drone's in the cab.
Thanks for posting the link for the catless Y-pipe, wish I would of had that last fall!!
I used like an 18" Magnaflow on mine. Lost some whistle but it made things more livable for daily driivng. I just made a flange so I could easily remove the muffler for racing or when I wanted to be obnoxious.
