STS guys only !!!
My FLT level V 4l65 will be ready soon and the time has come to decide on a converter. I put this in the FI section because I need people that KNOW how a stall acts with a sts and a 6.0. I drive the truck everyday so no huge stalls. I want enough to leave the line with some boost, not lag.
side note: Why in the hell are you maggie guys reading this???
It all depends on the turbo,engine,stall,camshaft.... I would not worry about the 2 step till it gets violent... I have had nothing but problems from mine... size matters also....... and will effect how they work... 9.5 - 10.5" you will be fine with a 3200... Then you can footbrake 3600+ 6psi or so ? that would be great
Thanks for the info. I have been under a rock for a year or two. I have not heard of the hydro conversion. I want my truck to pull away from red lights somewhat stockfish as I drive my GMC more than the Z. I would be worried I could not hook more than a couple of pounds of boost.
What do you guys thinks a circle d 3200 278mm would act like behind my combo?
Thanks again for the great info!!! Keep it coming.
