STS guys only !!!
Old 01-28-2010, 12:28 PM
WJ MARK's Avatar
Originally Posted by slowec
My FLT level V 4l65 will be ready soon and the time has come to decide on a converter. I put this in the FI section because I need people that KNOW how a stall acts with a sts and a 6.0. I drive the truck everyday so no huge stalls. I want enough to leave the line with some boost, not lag.
side note: Why in the hell are you maggie guys reading this???
did you upgrade to a hardened output shaft??? you might want to if not.
Old 01-28-2010, 01:01 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
You guys need to learn the SyTy shuffle... (do a search, I've typed it too many times already lol)
With AWD I could footpedal more psi than torque steer made safe No hydro conversion either. That doesn't translate for 2wd because the power is reduced to each wheel, but that was also with a bigger turbo and the 408 plus heads and cam.
Old 01-28-2010, 10:06 PM
1BADAZZSS's Avatar
Originally Posted by fastlt1
What rpm can you foot brake to and what PSI? Are you leaving off a 2 step?
3600@10psi on the street with stock tires. No 2step. I found my 2step not needed since I have hyrdoboost
Old 01-29-2010, 02:38 PM
Sleeper04's Avatar
I'm running a Yank TT3000 with a Masterpower S70 turbo and using the syty shuffle, I can build 5psi at the line. I daily drive my truck and have a 40 mile 1-way commute with no issues. I'm running 3.42 gears.
+1 on upgrading to billet shafts.
BKnBLK05
12-28-2015 08:52 PM
Go5.3tt06
09-12-2015 09:29 AM
fillpot
07-26-2015 07:21 PM
lxcoupe
07-21-2015 02:12 AM
GM-only
07-19-2015 10:48 PM
Quick Reply: STS guys only !!!
