STS kit ON only 4psi
Old 10-06-2007, 04:04 AM
If you wrap the exhaust, it will booost better. Also, check for leaks in the charge pipe.
With the intercooler, run your boost reference to the intake, and not to the turbo. The intercooler causes pressure drop.
Old 10-06-2007, 10:03 PM
sowaidi's Avatar
thanx a lot, ill look at it
Old 10-06-2007, 10:59 PM
Stampede4ever's Avatar
What is your AR on the turbine side?
Old 10-07-2007, 04:25 AM
sowaidi's Avatar
i beleive its .81
Old 10-07-2007, 12:41 PM
GFYS and STFU
Spoolin's Avatar
That's your problem right there! That's a pretty big A/R for a 4.8 At least your not gonna run out of turbo at higher RPM's. But then again with your manual so you can pick when you wanna drop the clutch.
Old 10-07-2007, 01:08 PM
kbracing96's Avatar
The fact that it's a 5 speed isn't helping first gear spool. It got a deep 1rst gear that doesn't load the turbo very hard, so it doesn't build boost too fast. Wrapping the exhause and putting a .68 A/R exhaust housing on it will make a lot of difference. That's what I had on mine and it boosted quite well.
Old 10-08-2007, 10:59 AM
You could block off one of the port flanges or partially block it off. See if that helps, for a cheap fix.
Old 10-08-2007, 02:00 PM
GFYS and STFU
Spoolin's Avatar
Not sure I follow, could you explain that one a little more? thanks
Old 10-08-2007, 06:05 PM
sowaidi's Avatar
i dont quite understand what u mean
Old 10-08-2007, 08:56 PM
If it has a dual scroll turbine, just make a plate to block off one side. (The plate will go between the mounting flange and the turbo) Which should effectively lower the AR.
Chad.
Quick Reply: STS kit ON only 4psi
