STS Methanol instructions.
On the wiring harness to the sts methanol injection kit, were does the (Injector Ground Wire) go to? also the green wire on the harness does that go back to the valve to the boost controller by the turbo?
It's been a couple of years since I put mine in. The green wire is easiest to install at the high/low boost switch in the cab. (the opposite end of the solenoid valve) My kit came with a 12A solid state relay to ramp the meth pump up and down. The injector ground wire from this relay goes to my piggyback for progressive control, but it should work spliced into a fuel injector ground (through a Hobbs pressure switch when boost is made)
ZO6Ted
08-12-2015 07:50 PM
grounding, injection, installation, instructions, metanol, methanol, methonal, performance, relay, solid, state, sts, truck, trucks, wiring
