STS PCV Switch valve necessary?
Originally Posted by johnrusso1987
On second thought, what can I get away with in this situation...I probably should get new pistons, but can I replace the one and try again?
This is a very good point, but I don't have a lot of time to spare in this situation, not to mention the cost. I know I can find someone to help me with a build in my area, but I would like to know where to find the best parts.
Can someone list out some solid parts that I'm gunna need, plus anything else I should look into?
before you jump off the deep end, do some good ole trouble shooting and run a compression test.
ya that will be the first thing I'm going to when i get home, but i just wanted to do some homework to see what I could be in for.
outstanding case, you might not have a problem at all....it might have some other issue. the way I see it you are in the same boat as me, you have the same symptoms. I would go right for piston #7 and check the compression.
