STS PCV Switch valve necessary?
Old 04-20-2007 | 10:16 AM
  #41
vanillagorilla's Avatar
Ummm...well that be it then. I still don't think a blown head gasket would cause oil to blow out everywhere.
Old 04-20-2007 | 10:17 AM
  #42
ILLINTENT's Avatar
$20 bucks says it's a blown head gasket
Old 04-20-2007 | 10:28 AM
  #43
johnrusso1987's Avatar
I'll let you know about about 2.5 weeks when I get home....
Old 04-20-2007 | 01:52 PM
  #44
TG02Z71's Avatar
Originally Posted by johnrusso1987
Ya I forgot to mention something else too....I have a small coolant leak also that drips in the front of my block onto the floor also that I couldn't pinpoint the direct source of.
That is probably the notorious water pump gaskets. Do a search on it, it's a common problem you will see posted here. Hope its not your head gasket.
Old 04-20-2007 | 03:23 PM
  #45
logan214's Avatar
Now I'm lost, I'm getting my compression test done Monday. Correct me if I'm wrong but I thought if I had a blown head gasket or f$%d piston, wouldn't it be smoking from the tailpipe? By know means do I know what I'm talking about, only what you nice folks have taught me.
Old 04-20-2007 | 03:51 PM
  #46
BlownChevy's Avatar
blownerator
Check the compression....I am sure that I had both a blown head gasket and cracked ringlands.
Old 04-20-2007 | 05:19 PM
  #47
These kits need a damn warning label.
Old 04-20-2007 | 10:03 PM
  #48
Wilde Racing's Avatar
How do I change this text
Originally Posted by ILLINTENT
I'm surprised more people aren't sugesting a blown head gasket- Am I the only person that noticed he mentioned "milky oil" coming out of the PCV?? That would explain the miss and everything else, plus a little ping on boost will almost always at least partially blow the head gasket if it's severe enough to hurt a piston.
look at post 28....
lucas287
31
01-12-2021 06:18 AM
Texas5.3_1251
03-05-2016 08:10 PM
FlyingLow
11-24-2015 10:05 AM
lxcoupe
09-11-2015 03:17 PM
jtphelps289
09-01-2015 08:58 PM
Quick Reply: STS PCV Switch valve necessary?
