Sts turbo install--Tune and fuel
Old 02-08-2007 | 11:45 AM
leanlow's Avatar
Question Sts turbo install--Tune and fuel
Hey, everyone been awhile since i posted on here. Anyways, i am buying an sts turbo from a member on this forum. It has a gt-67 turbo and fmic. My motor is still stock 5.3L and fuel system is stock.
My questions are:
1.Will the stock fuel pump be ok if i upgrade to 42# injectors and run 6psi boost? (dont want to go over 6 due to stock motor at this time)
2.What is the best tune, on a budget here (had to talk wife into letting me have this, some people will know what i mean ). Looked at a local dyno tune but it is 400+150/hour said it would be about 1000-1600$
Spec. on truck below.
Old 02-08-2007 | 11:57 AM
MrXerox's Avatar
Old 02-08-2007 | 11:59 AM
leanlow's Avatar
Yeah, to high for me.
Old 02-08-2007 | 01:58 PM
quicksilverado's Avatar
Upgrade the fuel pump. The stock one is not sufficient for the 42 lbers. Don't ask me how I know.
Old 02-08-2007 | 02:20 PM
leanlow's Avatar
Anyone got a link to where i can purchase the walbro fuel pump?
Old 02-08-2007 | 03:12 PM
thunderwagen's Avatar
Get a walbro 255lph in tank and look at Nelson for a tune.
Old 02-08-2007 | 03:14 PM
spinz71's Avatar
I know you said you are on a budget, but since you'll have the 67 and fmic and have to buy injectors, I'd go with 60s injectors and a Walbro 340. Down the road, all you have to do to up the boost is change out the WG spring and retune. I'm running 10psi on a stock engine except for the pushrods and springs.
I'd recommend Nelson for the tune. Out of the mailbox, it was pretty darn close and he was able to complete a street tune in less than an hour.
Old 02-08-2007 | 06:01 PM
Spoolin's Avatar
GFYS and STFU
I didn't use a Nelson tune but people swear by them. STS uses the Predator tune. I'm not sure but I assume if you call them up they might help you with your tune free of charge, they were really good about mine. In the end though I went with a personal tune from a shop because I didn't have confidence in the guy that tuned my truck the first time around. Turns out I was right because after a $650 tune I had an extra 45 hp. I'm running an MSD booster pump with 44#'s. Works for me so far. Might be cheaper to get a fuel pump though.
Old 02-09-2007 | 05:52 PM
leanlow's Avatar
One other question, with a gt67 turbo with the sts system when does it reach full boost? Also what is a good elec. boost control? been looking at the aem one link here
http://www.aempower.com/ViewCategory.aspx?CategoryID=68
Old 02-09-2007 | 06:55 PM
nonnieselman's Avatar
check the classifieds for a Walbro. i got one for $120.
its cheap insurance!
Where you located at in TN?
Might could find a local member with software?
