STS and Water to Air Intercooler
Ok, I am working on a water to air intercooler for my STS kit (fortunately I havent yet cut any stock pipes, only drilled a whole in one). But here Is what I am doing, I have put the IC in the stock air-box location (post maf), and am planning to relocate the IAT sensor the 30* elbow that goes into the TB. So here is what I am wondering. Will having the air metered before the IC then taking the temp after the IC play hell with my tune? If it will I have come up with some solutions.
As you will see in the attached image below where I have put the IAT, the maf is in the stock location. I am considering moving the Maf to point "A" about where the coupler is now. Thats really the only solution I can come up with. (PS if any of you are interested, I will offer HP gain results after I am retuned). Any suggestions, advice, help? I am really in uncharted territory for me right now. HELP!!!
I would think you would be fine like that. Thats sort of what the radix guys do i think. They put the IAT in the intake manifold, and leave the Maf in its stock location. So i would think it would be okay. On a side note, how does that 90* silicone coupling look when the truck is idling? The one going into the intake flange. Does it collapse under vacuum? Have you looked at it when the truck is running?
single digit dreamer
i cant say for sure but i think it will mess with your tune some. i would stick the maf in where that coupling is like you said. i have always had the maf post intercooler and had consistant tuning with it there. is there some reason you dont use the iat sensor that is built into the maf?
Dont all the radix guys do it just like he is talking about? Maf stays at home place (pre I/C) and the IAT sensor moves to the intake (post I/C)...at least i thought so......maybe im wrong.
