supercharger
supercharger
just looking around at superchargers and found this is it a good deal. Silverado Stage3 Supercharger - TVS1900
only: $4999.99
Stage 3 Motorsports Supercharger Kit for GMs 2007-2009 GMT900 Series pickup trucks and SUVs with the 5.3L engine.
It features the all-new Eaton TVS 1900 Supercharger with integrated intercooler.
This package is the culmination of over one year of on-road and dynamometer testing and validation. The kit safely provides 9 psi of boost creating stump-pulling torque and neck-breaking acceleration. At the flywheel, this kit increases the power and torque of the 5.3L to 450 HP and 450 ft.-lbs. respectively.
Stage3's supercharger package provides an OE appearance under the hood and includes all necessary mounting hardware. Computer tuning is done by sending your truck or SUVs PCM/ Computer to Roush Performance in a prepaid overnight box. The PCM is tuned by the engineers at Roush Performance and sent prepaid overnight back to you. This means your vehicle will be down for 3 days.
Installation:
4-6 hour total install time
Not required to drain cooling system
Not required to cut or modify base vehicle
Vehicle can be returned to stock if required
Included:
Supercharger/Manifold Package
Low Temp Intercooler Radiator
Intercooler Reservoir
Mounting and Wiring Hardware
New Accessory Drive Hardware and Belt
High-Flow Fuel Injectors - 42 Lb Per Hour
Colder Heat Range Spark Plugs
Prepaid overnight Fed Ex box for PCM tuning
New Supercharger to Airbox Intake Tube
Customers must purchase the following two items not included in this kit:
TMAP Sensor (GM P/N: 90423637) TMAP Wiring Jumper (GM P/N: 88988320)
It is suggested that customers also purchase the following:Intake Gasket Kit (GM P/N: 89060413)
Kenne Bell Boost-A-Pump - Is Strongly Suggested
only: $4999.99
Installation:
Included:
only: $4999.99
Stage 3 Motorsports Supercharger Kit for GM€™s 2007-2009 GMT900 Series pickup trucks and SUVs with the 5.3L engine.
Installation:
Vehicle can be returned to €œstock€ if required
Included:
only: $4999.99
Installation:
Included:
just PM him and see what he can do. He's a great guy and very easy to get along with. He will answer any questions and also fill you in on his knowledge of what goes with what and what you need or dont need
