supercharger coolant
If you leave your car in the garage you probably would be fine too.
It works out for both locations in florida since it never freezes they can make use of a better coolant option. But here in texas where it does get nice and cool during the fall winter I would assume the blower runs a whole lot better with ambient temps being far down, but yes you have to factor in dexcool. Its a give an take situation.
What is wrong with dexcool?
Nothing wrong with dexcool I will run it in the engine and blower.
My tank is about the same as well, got biggest I could comfortably fit. Which should aid in better cooling. I went to orileys today to look at some stuff and they only sell 50/50 mix here. Nothing concentrate, I guess is ok just paying for their markup on water and coolant
I run a contrasting color coolant from the engine, so if there's a leak/issue I can isolate one system from the other. Usually Dexcool in a GM, and then a blue Nissan coolant in the intercooler system. Make sure to check freeze point depending on the climate the vehicle will be in.
makes children cry
same here. i actually just bought some generic gold, mix-with-anything version to flush my intercooler system out in a few weeks.
dexcool in the car, so i wanted another color for the blower. i looked at the blue & purple ones, but they're apparently silicate-hybrid OAT, and i didn't want to risk a clog after having previously ran dex in the blower.
smokinlmm (08-24-2024)
02Vortech
03-27-2007 08:20 PM
