Superchargers, Blowers, & Gas Milage?
How big of differance in fuel mileage did you all notice when you supercharged you trucks? Was it drastic. For the price / power you get from them it's worth it. But if it totally kills the fuel mileage of a DD then is it worth it. does it then just become a race truck? I'd like to do it if the F/M isn't waisted..Thanks
Turbos will definately NOT get your better gas milage, especially if you do a rebuild intended for a turbo motor.
Typically, the order is NA/turbo/SC
look up typical BSFC values. NA is around 0.5, turbo is around .55 and SC is around .6
(meaning it uses 0.5lbs of fuel for every hp produced)
Tin Foil Hat Wearin' Fool
If oyu drop CR put a turbo cam in etc etc of course oyu will lose mileage but if you only add the system and keep your foot out of it in most cases with a turbo you gain mileage from what I have seen/read. Hopefully soon I will be able to verify this myself.
Sure dude. There are plenty of people on here that ahve gained mileage from putting a turbo on their vehicle. Jerry2500 gained like 2.5-3mpg.
Performancetrucks.net: physics and logic need not apply.
