Swapping pulleys on my Radix ???
I think I want more boost. What can my stock 5.3 handle with pump gas? 91octane is about all that can be found around here. I currently have a 160 deg t-stat to install and two smaller pulleys, a 3.0 and 3.1. A new tune is a given but is there anything I should consider when swapping pulleys?
91 Octane..ouch that sucks IMO. Your running a 3.4 now so ya a tune is all i would worry about at the moment. I dont see that your running a cam or anything that would maybe suggest upgrading injectors.
TOTM: January 2007
I think you will be okay with the 44# injectors with the 3.1 pulley. Your IDC may get up into the 90's though. I would buy a methanol kit before larger injectors. The meth will keep your intake charge cooler and add octane so you can run a smaller pulley without detonation. IMO
