switched from supercharged to turbo
#51
12 Second Club
yeah, definetly need better brakes now! i have plumbed in two walbros, added another wastegate and hooked up the boost controller. i was hoping to make it to dinwiddie this weekend but the weather doesnt look to promising. i was curious to see what traction is going to look like with the leaf springs and caltracs. i will be putting in a 4link over the winter!(and brakes!) thanks again frost! hes got me tuned dead on @ 15psi on pump gas/meth. i finished permantly mounting the boost control solenoid last night. here are a couple more pics.....
#52
I have spoken to Aeromotive before about building my fuel system. They suggest at least a -8 return line on even a low horsepower build. I think your -6 is choking off your regulator. Aeromotive said you don't want your return line regulating your regulator. Just a thought. Cool build, I let my 1980show truck go after a layoff.
#53
Performance Trucks Sponsor
I have an aeromotive setup as well, and I used to run a -6 return line.
I measured pressure on the return line because I was concerned as well and it was at 22psi.
I now run a -8 just incase.
Just posting to give a start on discussing this.
Also, if they suggest a -8, I wonder why they only give you a -6 return hole in the regulator?
#55
Too close for missiles, switching to guns
Halloween beer pong at UCSB
Sorry, couldn't help myself. I think of Top Gun everytime I see this posting...
Regarding the return line, it seems like a majority of the postings I see in the fueling section of LS1tech is using a -6AN return. Is the 22 psi a problem? What is the psi with a -8AN?
Rick
Rick
#56
12 Second Club
definetly! hows yours running? id like to hear from you. im tuned @15psi for now. mine wont be on the road for much longer. after the first of the year im putting it back in my shop for another round of mods, 4link, 4l80, transbrake, etc.....
#57
12 Second Club
hey dmaxxr, im kind of wondering the same thing. the only reason i went with the -6 return is because the port size is -6. i have`nt had any problems with the two walbros.
