T-70 Hp???
a precision pt70 is rated at 820 crank, garrett gr42R-70t is 850 rated, a turbonetics tc70 is rated for 850. The garret is around $1200, the turbnetics is around $1000 for a p-trim (non-bb - 1300ish for bb), I don't know the precision pricing for that model (pt70).
the STS "GT70" runs about $1100 an is rated to 750-800, although I had mine up to ~850 (hit 600 on a mustang AWD dyno at 5300rpm and had to lift because the engine was on stuff on fire). It was definitely over cranked at 14psi with the 408 (98* ambient if memory serves).
(good call Jim )
(good call Jim )
hey erik. put some $$ signs in there if you could.
mp70 is good for 600rwhp on a 5.3. prety sure the precision gts 70's would be good for over 700rwhp on the same motor but they cost more than twice as much.
Are either of these units worth the trouble on a 5.3 ?
Just saw them a few days ago... Thanks.
SPECS:
$260.00
JDM T70 TURBOCHARGER
Stage-3 Turbo t70. 60.5 - Compressor Wheel.
64.5 Shaft & Wheel, 70 A/R Compressor Housing. (12-22PSi).
CNC Machined Flanges 4Bolt Designed fit most After market Manifold.
Designed Usable for internal Gate Application. And/Or Use A T4 & T70 With An Internal Actuator . (4" inlet air flow).
SPECS:
$200.00
JDM GT45 T4 T04B TURBOCHARGER 1.15 AR.
25 to 35 Psi Peak Power Performance Output Capability.(factory warranty).
And/Or Use A T4 With An Internal Actuator
5 bolt pattern flange for Down pipe.
SPECS:
$260.00
SPECS:
$200.00
SPECS:
$260.00
SPECS:
$200.00
SPECS:
$260.00
SPECS:
$200.00
If anyone wants to reproduce Parish8's combo on a 5.3L here is what you need:
https://ls1tech.com/forums/showthrea...t=#post8073299
Sorry for the shameless plug....
Andrew
Andrew
That is a 60mm turbo. Way to small to make any real power, plus the ebay turbos are good for only being paper weights. The units are not balanced, they use standard shaft threading and the wheels are not even HIP'ed....etc..etc.
For the money the Pt70 or the TC70 are the best. The TC70 does have the 1 year no questions asked warranty which is very nice.
SPECS:
$260.00
SPECS:
$200.00
SPECS:
$260.00
SPECS:
$200.00
