In-tank pump for '01 silverado
This is the only one I could find listed specifically for our trucks: Holley-Walbro Fuel Pumps / Speed Engineering Performance Parts - LS1, LS2, LS3, LS6, LS7, LSX, LT1, Camaro Parts, Corvette Parts, GTO Parts
Anyone run a Walbro 255 with a boost-a-pump? I'm right there at its limits too. In my case, it wouldn't take a huge hit from the BAP to satisfy my needs. Just a few extra volts above 5psi would do it. I just hate to fool with a regulator and extra plumbing if not absolutely necessary.
This is the Mustang pump (centered inlet) in an '03 bucket (I think your bucket is the same) and it is defiantly a cleaner install than the Camaro pump as far as how it sits in the bucket. I would search around and see if you can find out exactly how big the fuel inlet is on each pump. If they are the same size I would order the Mustang pump kit and the fuel sock for the Camaro kit separately. If they are different sizes then just order the Camaro kit.
The fuel sock that came with the Mustang kit wouldn't fit because of how the edges on the bottom are formed.
5.3lSilverado
25
08-29-2016 12:48 AM
Mossyoakglock
07-17-2015 08:30 AM
