tc78 questions
I think it would be fine on a 402 with only spinning it that fast. I like to keep turbos a bit on the small side in trucks any way, just so your in the usable power band of them any way. A big turbo is great if your building a track only car and can launch with a 2 step all the time, but for a street driven vehicle like your truck, a smaller turbo on a bigger motor is WAY more fun! Almost no lag, but still has a descent top end
i figure it this way i could crank the boost on a small motor and make XXX power or i can have low boost on a big motor and have the same power. i don't want over 2 bar (14.7 here at sea level) and the smaller motor will have to go over the 2bar. i say that because with my ecu my fueling table with a 3bar setup is stupid. the ve table doesn't get bigger the accuracy just gets worse from 2 to 3 bar.
but my question is, with the stroker cranks have they fixed the oil burning issues it seems some guys have? i heard some blocks with shorter skirts have oil burn issues but other blocks with longer sleeves don't . which is which and is it true?
TAPyvehc93
09-12-2015 08:19 PM
