TC78 vs T76?
Old 08-05-2009 | 12:06 AM
stock48's Avatar
9 Second Truck Club
Default TC78 vs T76?
Thinking about upgrading to a TC78 with a S trim wheel. Right now Im running a T76 with a p wheel. If anyone has tested a Tc78 vs a T76 I would like to hear about it. Looking for another 50~75HP, and a couple hundred RPM.
Old 08-05-2009 | 12:11 AM
Derek @ EDO's Avatar
FormerVendor
http://forcedinductions.com/productturbonetics.htm
Looks like it will do the trick.
I would call Jose @ FI
256-658-5798
He can tell you exactly what that turbo can do for you, he is a great guy give him a shout!
Old 08-05-2009 | 12:28 AM
stock48's Avatar
9 Second Truck Club
256-658-5798
Thanks! I got my current TC76 from him. Looks Like that T78 street unit might do the trick
Old 08-05-2009 | 09:25 AM
TrickTurbo's Avatar
Truck Sponsor
GEt the PT88 50+100 youi know you will want more once you get to that point.
Old 08-05-2009 | 11:40 AM
hellbents10's Avatar
LS1Tech Sponsor
GTM78 with a F1 turbine wheel and a 1.15 turbine housing. That will get you another 100hp. There is some new T4 t-netics configurations that will be getting close to the all mighty PT88 though.
Old 08-05-2009 | 01:47 PM
stock48's Avatar
9 Second Truck Club
I don't want an 88. My goal is to get into the 9's with less 80MM, all boost. There is at least .2 in the combo I have right now with better air, and 16psi but I think a high 10.0 or low 10.1 is all it has.
Thats what Im looking for. Does the F wheel flow more than the S? I know my exhaust is holding me back because when I had the my old T76 with the Q wheel the truck ran harder, and wanted more fuel at the same boost#.
Old 08-05-2009 | 02:20 PM
SincalT/A's Avatar
What size is your DP?
Old 08-05-2009 | 02:34 PM
stock48's Avatar
9 Second Truck Club
3.5'' with 3.5'' exhaust.
Old 08-05-2009 | 03:06 PM
nonnieselman's Avatar
I would try a 4" exhaust without changing anything else and see if you get any gains..?
Old 08-05-2009 | 04:03 PM
I would like to know also...
