teach me about turbo cams
#23
11 Second Truck Club
If your heads don't flow any better at .630 lift then they do at .550 lift, then you won't gain anything except more stress on your valvetrain. Our stock heads and mildly ported heads seem to like anywhere from .540-.600 roughly.
#25
BUT, As long as the heads don't decrease in flow above that previous lift (.550) you are actually gaining degrees (time) that the valve is open allowing that flow to happen at the higher .550" rate rather than a lower rate with a cam with max lift of .630". It's gaining area under the curve, amount of flow capacity that the valve will allow, and in this case, is aided in by the Turbo compressor. Just like the "quick lift" cams from Crane, and similar designations from Lunati, Isky "max flow", la la la la...... It's widening the parabola that is the lift curve.
If your valvetrain is built for it, and the heads don't drop off, no reason not to try.
lxcoupe
07-27-2015 08:19 PM
