Throwing belts:(
Old 02-03-2012 | 06:31 AM
bud8fan's Avatar
check pulley alignment with all of them...specially crank pulley
Old 02-03-2012 | 06:44 AM
dick_landy's Avatar
Originally Posted by 08cheyennesc
A manual tensioner won't work on a blower ,the belt stretches a lot at high rpms ,he got the correct tensioner.
This is what I used. Worked great.
New MTI Racing Belt Tensioner for Camaro - MTI Racing | Corvette Performance Parts | Camaro Performance Parts | LS Crate Engines | Corvette Road Racing Parts
Old 02-03-2012 | 08:22 PM
TIM Z's Avatar
11 sec. Truck Mod
^^^ Very cool product man!!
Old 02-03-2012 | 09:34 PM
blwn4.8's Avatar
well today I adjusted the pulley between the blower and tensioner and I also put a 110 inch belt instead of 110.5 so hopefully it fixes it... how do I check the alignment on them?
Old 02-04-2012 | 01:03 AM
Blown06's Avatar
8 Second Truck Club
The power steering pulley could be a problem as well
Old 02-04-2012 | 01:19 AM
dick_landy's Avatar
The problem lies in the rotating mass of the blower. Spring tensioners are just too wimpy with big horsepower, fast revving motors. Im guessing its coming off when you snap the throttle? Use a straight edge to check belt. Using the smallest belt possible will help too.
Old 02-04-2012 | 10:30 AM
blwn4.8's Avatar
Threw the belt off again, how can I check the pulley alignment?
Old 02-04-2012 | 07:17 PM
blwn4.8's Avatar
problem solved! it was an idler pulley on the driver side that was making the belt slip off! Its now putting out 12 psi with the bigger pulley! Anyone need a 2.8 pulley by any chance?
Old 02-04-2012 | 07:32 PM
TIM Z's Avatar
11 sec. Truck Mod
Hey Bro , you can get dayco 101mm idler pullies for about 23$ a piece at the part store, they work great and will help take slack out of your belt.
Old 02-04-2012 | 08:16 PM
blwn4.8's Avatar
That, exactly what I did! hopefully Ill be able to pull some good times at the track this week!
Quick Reply: Throwing belts:(
