time for a new turbo help Mr decide..
Old 11-05-2012, 01:11 PM
Jake99's Avatar
Default time for a new turbo help Mr decide..
Alright the time has come for a new turbo, I thought I had my mind made up but there's so many choices im about to pull my hair out! Right now I have a magnum 76mm bb p trim, 64.5-72 ex wheel. My setup is a stock 4.8 head studs and a 212-212 cam. I really don't want to run a trans brake if I don't have to, and converter will be decided once the turbo is on.
Ok I've decided I want a bw unit, t4 1.00ar 83mm wheel, now for the cold side IM stuck between a 72 and 75, race cover?? Bullit wheel?? Both add a big chunk of change to the turbo and IM kind of on a budget. Also what will the race cover do to spool time? Faster or slower? Will the 72 with a race cover spool better then a standerd 75?
I've pretty much set a goal of 800rwhp. So i want to know the compressor can make in 900-950 hp range
Old 11-05-2012, 01:20 PM
nonnieselman's Avatar
why not just go with the standard 75?
Old 11-05-2012, 01:52 PM
Jake99's Avatar
Little worried about spool time with the small 4.8. They seem a little laggy even on the 5.3s from what I've seen. Foose04 has the bullit wheel and claimed his was still pretty dead on the street, I don't expect it to be great but just trying to make the best out of it.
Old 11-05-2012, 02:14 PM
check this out. I just purchased one today. It is identical to the $1100 Magnum and Im 99.99% sure it's the EXACT same turbo. Its 80/77 1.22 ar T4
GT45 GT45R Ball Bearing Turbo Charger 80mm Wheel T4 1 22AR Big Power Anti Surge | eBay
Old 11-05-2012, 02:24 PM
Jake99's Avatar
Yeah I cot the thread over on tech about that, sounds like a good piece for the price! IM just a little concerned about how long they will last and perform compared to the bw. If they would of been out longer I may jumped on it. Mines 95 percent street truck and by the numbers I think it might have worse street manners then the s475
Old 11-05-2012, 02:45 PM
No it wont because the s475 has a way bigger exhaust side, unless you go with the T4 housing and 83/75mm turbine. The bw would prolly outlast this one but you can get 2 of these for the price of a T4 s475
Old 11-05-2012, 02:50 PM
Jake99's Avatar
Yeah this is true, and yeah I was planning in getting the t4 be. Keep us posted on how how it does I might use that on other builds later on. But I think I wanna stick with a bw unit for now.
Old 11-05-2012, 02:53 PM
Jake99's Avatar
Ok just got off the phone with forced inductions, he speced me a s475, billet wheel, factory cover, t4, 1.00 ar, 83mm wheel. 1149 bucks. What you think?
Old 11-05-2012, 03:04 PM
Should work well for your 4.8, but I would opt for the cast BW compressor. Recent tests have shown that the cast BW wheel makes more power than the billet batmowheel. Plus it will save you a little coin. I would also go with the 1.10 ar instead of the 1.0
Old 11-05-2012, 03:35 PM
Jake99's Avatar
Id like to do a little more research on this wheel then, you have a link or any idea where you found this?
Quick Reply: time for a new turbo help Mr decide..
