Time to refuel for more boost?
Old 02-26-2008, 01:18 PM
  #21
MikeGyver's Avatar
Originally Posted by Whippled 496
... DId the pump you bought drop right in, with the sock on the outside of the bucket like the stock pump does, or did you have to put the sock on the inside? Does your pump have 2 inlets like the stock pump? Do you have an issue with running out of fuel when below 1/4 tank under hard excel?...
The sock is inside the bucket. It has one inlet. I haven't let the fuel run that low yet, but there is no reason that the pump should suck air, all the check or flap valves in the bucket are operational.
Old 02-26-2008, 02:29 PM
  #22
High on diesel fumes
thunder550's Avatar
My twin in-tank setup has both socks outside the bucket, flat against the tank bottom. Food for thought. I'm very happy with it so far.
Old 02-26-2008, 02:45 PM
  #23
03sierraslt's Avatar
What pump does the intank take? Mine is a GSS340 Walbro does the return setup take the same pump?
Old 02-26-2008, 02:57 PM
  #24
MikeGyver's Avatar
Got pics?
Old 02-26-2008, 02:59 PM
  #25
KySilverado's Avatar
FWIW. I have the stock in tank. Never touched. The inline that came with the Magna kit. 2-3 years now. Only time I drop fuel pressure is 1/4 tank or less. 60# injectors sitting on the work bench waiting for me to install. If either pump fails they will be replaced with the same.
  #26
Whippled 496's Avatar
Originally Posted by MikeGyver
Got pics?
Hey back off Mike, this is my thread.
Hey thunder, you got any pics?
Old 02-26-2008, 04:16 PM
  #27
TURBHOE's Avatar
is the pump that comes with the magnacharger the same gss340? if so in there instructions it does not show them hacking anything up at all. http://www.magnacharger.com/pdf/manu...00-2003-06.pdf
Old 02-26-2008, 04:36 PM
  #28
MikeGyver's Avatar
Those instructions are for a returnless system, our bucket is different.
Old 02-26-2008, 04:42 PM
  #29
thunder550's Avatar
Unfortunately no, I don't have any pics. It's a Racetronix twin in-tank setup. The bucket was cut up significantly to fit two pumps inside, but both of the socks were outside the bucket and resting against the bottom of the fuel tank. It came with a plug and play harness and a hobbes pressure switch to turn the second pump on at 4 psi. It is 1000+ hp compatible supposedly. I have 96# injectors, and with my 408 at 15 psi I see almost 70psi fuel pressure and a max injector duty cycle of around 60%. Racetronix may have more info they can give you if you get in touch with them directly.
Old 02-26-2008, 05:24 PM
  #30
WJ MARK's Avatar
Im in the same boat, stock intank, 255 inline. works fine.
Quick Reply: Time to refuel for more boost?
