Time to refuel for more boost?
Old 03-07-2008, 07:09 AM
  #61
Moderately Differentiated
dewmanshu's Avatar
IFR will be on the return system... 72.3
I thought the bolts were 10mm heads. 1" long is fine though.
Just swap the injectors and you'll be fine for now. reassess the fuel needs once you have the larger injectors in.
Old 03-07-2008, 07:43 AM
  #62
Whippled 496's Avatar
Thanks man, so its a 10mm head and its a #6 x 30mm (or 1")....what did you say about my asses?
Old 03-07-2008, 07:49 AM
  #63
dewmanshu's Avatar
you know what I sadi about your asses.
I bought my rail bolts at a local auto parts store. Small package hanging on those stupid metal clips at the beginning of an aisle. LOL
Old 03-07-2008, 10:08 AM
  #64
supersub's Avatar
remember it is a 6mm dia, 1.0mm pitch, and 30 mm long =@1 1/8,and they are eithe 8 or 10 mm socket.
Old 03-07-2008, 10:51 AM
  #65
Got it!
Old 03-07-2008, 11:33 AM
  #66
kbracing96's Avatar
Originally Posted by Whippled 496
6mm x 1.0? You mean 6mm head with a 10mm x 30mm bolt?
6mm is the bolt thread diameter, 1.0 is the thread pitch and 30mm is the length. It will most likely have a 10mm head.
Damn, I'm too slow,
Old 03-09-2008, 02:47 PM
  #67
Hey, I was doing some reading up on the 42lb to 60lb injector installs and noticed something. The 496 has a completely different fuel rail than the small blocks. I am going to post up a pic of my fuel rail that i took back when i had to change it out due to a leaking schrader fitting. Take a look at this and see if it looks like it would present an issue with my swap. I plan on doing the swap either after work one day this week or next weekend. I have all the parts now and its just a matter of getting the time to do it. I realize im probably just going to have to dig into it and see what happens, but i thought i would post a pic incase anyone notices anything obvious. The connecting rail does not come off, but it does swivel......looks a little bigger in diameter than the small blocks and a little tougher to have to bend if i need too.
Old 03-09-2008, 03:07 PM
  #68
kbracing96's Avatar
Humm... I don't think you will have a problem,as long as there is room for it to come up 5/8 of an inch. Guess you will just have to see
Oh and i think you should send me a set of those adapters to "help" you R/D them After all, I was the only one to contribute to you intercooler fund
Old 03-09-2008, 03:20 PM
  #69
LMAO!! I still have that dollar around here someplace.
I am worried about my intercooler that sits on top of my intake. I think the rail might hit that when i bend it up a little. I will have to just wait and see what happens.
I sent you a PM.
Old 03-09-2008, 03:29 PM
  #70
Nah....I think I'm good to go with the height of the rail. Here is a blast from the past when i had the DMAX intercooler on there. You can see the intake tube in the back along the firewall with the 90* in it where the whipple intercooler sits now. Looks like i have a few inches there at least.....so i should be good.
Quick Reply: Time to refuel for more boost?
