Time to refuel for more boost?
Old 03-09-2008, 03:36 PM
  #71
kbracing96's Avatar
HAHA, just use a hammer to "clearance" if needed
Old 03-09-2008, 03:54 PM
  #72
Whippled 496's Avatar
Yeah sure....i just need to find my 12lb maul hammer....that should do it. By the looks of that last pick, i dont think clearance is going to be an issue at all. Now all i need is some time......maybe i will get "sick" Friday .
Old 03-13-2008, 11:53 AM
  #73
I have my IFR table set up and trying to get a few auxilary tables taken care of (If i even need too). What about pulse width, voltage correction, injection timing, etc? Do i need to adjust any of these when going to the 60's? I didnt touch anything other than the IFR table when i went from 31lb to 42lb injectors so i was just wondering if this swap will be basically the same? How about idle tables? Do i need to adjust any of those with the new 60lb'ers? I have a return fuel system in my truck and not the returnless, i heard that may make it a little easier.
Old 03-13-2008, 01:53 PM
  #74
DrX
DrX's Avatar
It will run if you don't, but the tables really should be corrected for the new injectors. Trying to get hold of the correct data is not easy though. There is a long thread on the HPT forum about the 60's. I don't have the link handy, but someone actually had them tested to collect the offset data. Seems to make a difference.
Old 03-13-2008, 02:02 PM
  #75
MikeGyver's Avatar
I've been following that thread: http://www.hptuners.com/forum/showthread.php?t=14101
  #76
03sierraslt's Avatar
That might be the thread I started.... Ill try to find a link
Old 03-13-2008, 02:41 PM
  #77
I am using EFI, but i assume i can make the conversion from thier tables to mine.
Old 03-13-2008, 02:45 PM
  #78
kbracing96's Avatar
I am using EFI, but i assume i can make the conversion.
Get it figured out so I don't have to,
Old 03-13-2008, 02:49 PM
  #79
Eph eue.
Old 03-13-2008, 02:55 PM
  #80
kbracing96's Avatar
Eph eue.
Is that French?
Quick Reply: Time to refuel for more boost?
