Too late to go boost now?
Old 08-08-2014 | 09:03 PM
  #31
kbracing96's Avatar
Originally Posted by TRD_Tundra
No lie I'm still scared to do it but what the heck. E85 and meth should keep it alive and I have good faith in my tuner, he pushed a full sized truck stock bottom end 5.3 into the 9's and just about every 4.8/5.3 he builds runs 10's(Tellez Motorsports)
Actually the kit showed up today to a friends house. Super fast shipping 2 days after sending the payment, unfortunately I'm out of town at the moment and wont be back til 2 weeks. But as soon as I'm back I'll try to have it done within a week.
When you get it running and wanna hit the track, let me know. I'm down for HMP or Baytown. I'll bring my pig out! lol
Old 08-09-2014 | 08:14 AM
  #32
Blackpanther99's Avatar
I wanna see that^
Old 08-09-2014 | 12:16 PM
  #33
TRD_Tundra's Avatar
Alright guys can someone give me a detailed explanation on why a loose converter won't work with a boosted set-up?
Old 08-09-2014 | 12:49 PM
  #34
anheuserbusch08's Avatar
Loose converters tend to slip especially under boost. You'll end up blowing through the converter with the amount of boost u want.
Old 08-10-2014 | 02:13 AM
  #35
Go5.3tt06's Avatar
Just did lol. Ordered an On3 kit, gonna start looking for some 120lb injectors or so and dual walbro 450's.
My Torque converter feels super loose compared to my bro's boosted ext. cab with a Yank 3600
Don't mind if I share with ya. Why need dual pump 450? I thought single 450 would able make 600-700 hp max? With 60 lbs injector. That's one I ordered.
Old 08-10-2014 | 02:52 AM
  #36
subeone's Avatar
If you plan e85 then go for it, just make sure you compensate about a 30% increase in fuel, and make sure you get an OS with e85 compatibility as well as buying the e85 flex fuel sensor and wiring it in to have flex fuel capability. Theres no need for e85 and meth. Its either e85, c16, or pump +meth. c16 is my favorite out of the 3, especially in my side of Houston where e85 stations are limited. The on3 kit fits very good, it even fit in our OBS with just modification to the crossover!
make sure to run a boost referenced regulator, a return line, and dual feed to the rails.
Old 08-10-2014 | 07:07 AM
  #37
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by ScreamingL
right setup can easily make 600 rwhp on 10 psi but not every setup out there will do so
And I never said that it or another setup wouldn't do 600 did I George ? I said 650 to the tires , that's what the OP wants , he'll need more boost for that .
It depends bud , with a single 450 and 60# inj return style system I was close to maxed out around 12psi and did around 580 to the tires , but with methanol it's enough for 15 psi 650ish to the tires . Just my experience
Bad *** looking truck OP !!!
Old 08-10-2014 | 08:41 AM
  #38
GMCtrk's Avatar
Is that on gas or E85? Those numbers seem accurate for E85, but a single 450 should be good to 750 rwhp on gasoline.
Old 08-10-2014 | 10:37 AM
  #39
Atomic's Avatar
I have a gauge for that
Ill just leave this here and yall can figure it out, https://www.performancetrucks.net/fo...p-flow-510434/
Old 08-10-2014 | 11:27 AM
  #40
George C....'s Avatar
Formerly ScreamingL
650 rwhp is still possible at 10 psi but not all setups will do this
