Too late to go boost now?
Old 08-10-2014, 10:28 AM
  #41
TRD_Tundra's Avatar
I was planning on going with 2 AEM 320lph intank pumps. But I was reading that most trucks starve for fuel at WOT when they have belowe 1/2 a tank. If that's the case what other alternate routes should I take? I'd want a 23 gallon fuel cell in the bed.
Old 08-10-2014, 11:17 AM
  #42
gamble686's Avatar
2 aem 320s would be just about perfect. They make a e85 version and pump gas version so be careful. At 640lph combined it should be a nice happy medium between a single 450 and dual 450s. Cheaper too.
Old 08-10-2014, 11:23 AM
  #43
TRD_Tundra's Avatar
But would it have an issue with fuel starvation at WOT when the tank is at 1/2 of below?
Old 08-10-2014, 01:47 PM
  #44
gamble686's Avatar
If you are using a stock tank with modified bucket you shouldn't have issues. If you are planning on a custom fuel cell then it all depends on the design on the cell. Proper baffles and good design will prevent the sloshing that creates the starvation issues.
Old 08-11-2014, 04:57 AM
  #45
11 sec. Truck Mod
TIM Z's Avatar
Originally Posted by GMCtrk
Is that on gas or E85? Those numbers seem accurate for E85, but a single 450 should be good to 750 rwhp on gasoline.
I'm sorry I should have clarified that with my 60#s were pretty close to max , the pump was fine .
Old 08-11-2014, 09:13 AM
  #46
TRD_Tundra's Avatar
Modified bucket as in? Got any pics?
Old 08-11-2014, 08:04 PM
  #47
Blackpanther99's Avatar
Squash performance can do those^
Old 08-11-2014, 08:47 PM
  #48
Go5.3tt06's Avatar
Originally Posted by TIM Z
And I never said that it or another setup wouldn't do 600 did I George ? I said 650 to the tires , that's what the OP wants , he'll need more boost for that .
It depends bud , with a single 450 and 60# inj return style system I was close to maxed out around 12psi and did around 580 to the tires , but with methanol it's enough for 15 psi 650ish to the tires . Just my experience
Bad *** looking truck OP !!!
Dang it. I may need reroute for fuel system. Since I already paid single 450 pump and a 60s injectors. My bad. I thought I had 60 but I look at my box I have 80lbs injectors Will convert to return style and add FPR ON FRONT ENGINE MOUNT. That I want goal 700 max or maybe a little more. Want run 15-18 psi of boost.
Old 08-18-2014, 04:24 PM
  #49
TRD_Tundra's Avatar
Well'p. I'll be back in town in 5 more days. Turbo kit is here and waiting for my TrickFlow 95lb injectors to arrive aswell as both AEM 320lph pumps.
I really want to try meth injection with a 50 shot on the plate @12psi on E85.
Anyone here using both power adders (FI + Nitrous) on a stock bottom end motor?
Old 08-18-2014, 04:26 PM
  #50
oakley6575's Avatar
Foose04 did when he had his 4.8L. He was pushing 800+rwhp on the dyno and then put a 35 or 50 shot on top of that and made 919rwhp. A lot of guys use the small nitrous shots to spool the turbo off the starting line. its all in your tune. The stock bottom ends can handle it if the tune is perfect.
Quick Reply: Too late to go boost now?
