Towing w/ a radix
Old 10-17-2007, 08:59 AM
  #41
How do I change this text
Wilde Racing's Avatar
Originally Posted by BlownChevy
Maybe I should drive my truck up to Reno some day and we can see who is slower
I was just messing with ya
Old 10-17-2007, 10:51 AM
  #42
DrX
DrX's Avatar
Originally Posted by Wilde Racing
I'm not sure if this will help you, but here is a HUGE tuning secret of mine for 2 bar tow tunes..
Run in P.E mode all the time except decel. This is easy to do with HPTuner; you just command p.e fuel at anything over 1% throttle. (Not 0%, this keep DFCO working), then zero out your p.e fueling, and add fuel solely from you b.e fueling. You will be basically running open loop, but B.E fueling will add at 100 kpa regardles. That way 2 psi of boost gets 13.5 a/f ratio (or what ever you want) at 2,000 rpm or 6,000 rpm. This makes tuning for fuel mileage and EGT much much easier.......
That's what I was referring to(B.E.) with extending the commanded fuel table in boost. There is no B.E. in EFILive. I see that HPT also has the Main VE table extended instead of having 2 separate tables.
Old 10-17-2007, 11:43 AM
  #43
blownerator
BlownChevy's Avatar
I know
Old 10-17-2007, 01:06 PM
  #44
GFYS and STFU
Spoolin's Avatar
I know
I'm here Huckleberry!
Old 10-17-2007, 01:09 PM
  #45
blownerator
BlownChevy's Avatar
get your pile running first ......and thats "I'm YOUR Huckleberry"
Old 10-17-2007, 01:12 PM
  #46
GFYS and STFU
Spoolin's Avatar
Whatever *** hat!
Old 10-17-2007, 01:13 PM
  #47
blownerator
BlownChevy's Avatar
Whatever *** hat!
:yawn:
Old 10-17-2007, 07:59 PM
  #48
That sucks, because with a little rich a/f ratio at very low boost helps out a ton with torque...
Old 10-17-2007, 08:07 PM
  #49
what a rush!
moregrip's Avatar
so when do I get a ride in that STS truck of yours?
Old 10-17-2007, 08:15 PM
  #50
As soon as I get an engine that all 8 cylinders contribute equally....
As soon as I get a ride in a MP122 powered pick-up.......
Quick Reply: Towing w/ a radix
