Trick stage 3 on a h/c LQ4
Old 06-18-2012, 06:18 PM
AndysC3's Avatar
Default Trick stage 3 on a h/c LQ4
I have enough money to jump on the Trick Stage 3 but am not sure how it will preform on my 6.0L. I will install it with the mods listed in my sig. Eventually swap out the cam for the TU0, and may get the converter restalled to about 3200. So has anyone had the Stage 3 on a LQ4? Thoughts
Old 06-18-2012, 06:32 PM
Slowest turbo build ever!
black00chev's Avatar
How low in the RPM range does your cam start working?
Old 06-18-2012, 06:43 PM
AndysC3's Avatar
Have a 3700 converter now so. Around 3k. Peak torque is around 5200
Old 06-18-2012, 07:12 PM
Yea seems like if you get it restalled down to 3000-3200 that would help alot. I bet with the 76mm and .96ar you will see full boost by 3500. And with that cam coming on around the same time, I bet **** will get voilent around 4000 hahaha. Probably drive just like stock under 3k as well.
Old 06-18-2012, 07:36 PM
AndysC3's Avatar
well, If I do turbo Im looking at the TU0 cam. 216/216 .581/.581 113LSA. Should get a lot better low end. And eventually 3.73s
Old 06-18-2012, 07:48 PM
Well if you plan on changing cams then I see no reason not to do it!
Old 06-18-2012, 07:49 PM
02'Z71ONDUBZ''s Avatar
Cam and converter are not close to ideal, and neither are the gears. It will still work fine but would perform much better with a 3k stall and taller gears. The 60e will be on borrowed time as well. You have a pretty decent leap to make to have the ideal setup for a turbo, but that being said, you will have a newfound love for your truck with a snail on it. It will be a completely different animal.
Old 06-18-2012, 07:50 PM
Mod with training wheels
smokeshow's Avatar
Keep in mind that 4.56s will prolong the life of your 60e
Old 06-18-2012, 08:00 PM
AndysC3's Avatar
yea, its either keep the setup and do the Procharger, or change almost everything and do turbo. I already have the adaptor to run my AWD tcase with the 80E. Just need everything else lol. I can set the turbo on low boost. 6-7#. until I can get bigger injectors, cam, and 80e. Then turn up the boost. lol
Old 06-18-2012, 08:05 PM
13 Second Truck Club
A Low Dime's Avatar
Id say keep what you have and go procharger.
Quick Reply: Trick stage 3 on a h/c LQ4
