TrickPer Turbo Kit Install...Here I come
#111
I could not bend the AC line away from the DP without breaking, so, I had to cut and re-weld. Now I have max space that I can get from DP.
#112
79Ib/hr hi imp racetronix injectors with plug adapters are going in the truck.
TR6 spark plugs.
RX Dual Check valve Catch can
Vented oil cap
Now I have an issue with fuel pump. Currently it has 300LPH fuel pump (not the stock pump).
I have planned on running and inline 2nd pump, magnafuel MP-4301 pump with -8AN line and bulk head fitting to the stock. I already have all the parts and fittings. Now, the shop is reluctant to drill the tank are afraid it might leak.
So, I am looking now to do dual intank 300lph pumps. Should be good for 800rwhp because my current 300LPH pump was able to handle 450rwhp fueling for my previous 427ci engine. a 2nd 300LPH is available at the shop. I have Y-fitting with hose barb ends.
So, any quick reference for cutting stock bucket to fit dual pumps and also to wire the dual pumps?
TR6 spark plugs.
Vented oil cap
#115
#116
Has anyone dealt with Squash Performance? They make a kit with dual DW300 pumps that come installed in the pump module and you only transfer your sending unit to it and install it in place of stock pump module. It sells for $649 and will support 800rwhp.
#117
that looks pretty cool, is it just a direct drop in then?
I search for "dual intank pumps" but the search didn't come up with any. Can u post a link.
#118
