TrickPerformanceProducts NEW R&D truck
#151
Custm2500's Rude Friend
With just a change of 5 year old plugs to fresh new plugs while still strapped to the Dyno I saw it make a 20 HP gain on a wheel dyno...
I think your very first run was kinda low as far as numbers go. I believe a big part of that was the lack of matenance.
#152
dyno'd straight from the purchaser. I think the number where a little low, but that is what they where. You can never have a perfect dyno day, that just what they where at that time.
Pulled the plugs last night all seem to be fine, wrong ones but fine. The banging in the exhaust makes me think its fueling or ignition issues. Today I will getting some new plugs, wires, and checking the codes. Light came on while dynoing so it throu a code, probably tranny that been the normally one, but I will look today.
#158
Yeppers, sure were, stockers not sure how old or how long they have been there. Must have forgot to change them out. Oh well no biggie,
Did a compression check all cylinders are fine. I think we have an altenator problem, not suppling enough voltage/amps to keep all things happy.
#159
Unless the heads are lifting under boost.
#160
