TrickPerformanceProducts NEW R&D truck
Old 12-02-2008, 09:47 PM
  #151
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by TrickPerformanceProducts
Thanks I was thinking more, and might have been seeing how a problem arose, and got worse buring the dynoing.
01?
why, you have one.
What did you find???
With just a change of 5 year old plugs to fresh new plugs while still strapped to the Dyno I saw it make a 20 HP gain on a wheel dyno...
I think your very first run was kinda low as far as numbers go. I believe a big part of that was the lack of matenance.
Old 12-03-2008, 10:52 AM
  #152
Truck Sponsor
TrickTurbo's Avatar
dyno'd straight from the purchaser. I think the number where a little low, but that is what they where. You can never have a perfect dyno day, that just what they where at that time.
Pulled the plugs last night all seem to be fine, wrong ones but fine. The banging in the exhaust makes me think its fueling or ignition issues. Today I will getting some new plugs, wires, and checking the codes. Light came on while dynoing so it throu a code, probably tranny that been the normally one, but I will look today.
Old 12-03-2008, 11:48 AM
  #153
53RUSSELL's Avatar
yea 9psi with a 62mm turbo. I was hoping to start turning the boost up, but I do not think that is possible now.
Wouldn't make more power with 70mm turbo than the 62mm??
Old 12-03-2008, 12:07 PM
  #154
chevrolet all the way's Avatar
01?
why, you have one.
lol yep
Old 12-03-2008, 12:25 PM
  #155
Truck Sponsor
TrickTurbo's Avatar
Sure, but this is a standard kit on the truck. Larger turbo @ same psi is moving alot more air.
Old 12-03-2008, 10:09 PM
  #156
1FastBrick's Avatar
wrong plugs... Who put them in??? Or did you never change them???
Old 12-04-2008, 12:06 AM
  #157
WJ MARK's Avatar
I think they were the plugs that came in the truck.
Old 12-04-2008, 03:51 PM
  #158
Truck Sponsor
TrickTurbo's Avatar
Yeppers, sure were, stockers not sure how old or how long they have been there. Must have forgot to change them out. Oh well no biggie,
Did a compression check all cylinders are fine. I think we have an altenator problem, not suppling enough voltage/amps to keep all things happy.
Old 12-04-2008, 04:05 PM
  #159
Well atleast you know that the engine is fine.
Unless the heads are lifting under boost.
Old 12-05-2008, 12:49 AM
  #160
1FastBrick's Avatar
Gonna test again after swaping them out and fixing the alt issue???
Quick Reply: TrickPerformanceProducts NEW R&D truck
