TrickPerformanceProducts NEW R&D truck
Old 12-08-2008, 10:49 AM
  #171
Custm2500's Rude Friend
1FastBrick's Avatar
I will get you a test procedure for the crank sensor tonight...
Old 12-08-2008, 11:48 AM
  #172
Truck Sponsor
TrickTurbo's Avatar
This has been done so far.
Compresstion test done. #8 was 20psi off the highest #7 but the engine was cold. So that can throw the numbers off a little.
Installed new plugs
Installed new wire
Installed back up 04 6.0L coils
Check the tune, this is the same tune that has been in the truck for over 6 months but just now started having issues after the dyno setion.
Check the groung wires are all tight,
Added some 12ga ground to several lugs on fire wall etc.
Went into tune turned off egr and rear o2s.
Burned Arm and both hands. lol
Changed crank sensor with one from the 04 6.0L I have here.
Checked fuel pressure 48psi at idle 60ish at wot on the street.
Went for a drive and almost died in the street,
waited a second and away we go,
Builds boost no where near as fast as it should. Went wot tires spins hard but again not like before.
It feels like I am running on 7 or 6 holes even has that little shake to it.
Old 12-08-2008, 12:03 PM
  #173
I wonder if one of your injectors is going bad.
Old 12-08-2008, 12:15 PM
  #174
zippy's Avatar
Valve spring problems?
Old 12-08-2008, 12:32 PM
  #175
Truck Sponsor
TrickTurbo's Avatar
Any good ways to test these.?
Just tried a test drive and the truck almost died, when I stepped on the gas.. Waited a minute and away I went. Have nto checked valvesprings yet. I was thinking it was electrical but I am starting to get a little upset that its just not coming to me.
How do I get a misfire graph with Hp tuners? Trying to see if its one cylinder or a global thing.?
Old 12-08-2008, 12:35 PM
  #176
The only way, I have tested them was to install another set on.
Or if you have acess to a tech 2, I know that they can test them with it.
Try your stock one to see if the miss goes away.
Old 12-08-2008, 12:36 PM
  #177
sharpshooter's Avatar
If it was the injectors wouldn't you see that in your AFR?
Old 12-08-2008, 12:37 PM
  #178
They may not be spraying properly
Old 12-08-2008, 12:38 PM
  #179
Truck Sponsor
TrickTurbo's Avatar
Not sure if the 02 see it they will make the others pick up the fuel to offset that one hole maybe, not sure.
Electrics like this really make me miss a Distributor and a carb. LOL
Old 12-08-2008, 12:41 PM
  #180
Dumb ? here.
How long has the gas sat in the tank?
Quick Reply: TrickPerformanceProducts NEW R&D truck
