truck surging
Old 08-03-2010, 05:46 PM
bad cutt's Avatar
no the meth has been on the truck from day one
this just started.
Old 08-03-2010, 05:59 PM
MikeGyver's Avatar
Yeah, you need to do some logging. AFR, knock retard, and TCC would be a good start.
Old 08-03-2010, 07:57 PM
bad cutt's Avatar
its staying in lockup, no knock retard. ill have to check afr
Old 08-21-2010, 07:05 PM
bad cutt's Avatar
i finally had a chance to look at my o2 sensors today. they go to about 900 mv at wot. also boost moves from about 9 to 11 psi when the truck is surging. i havent changed anything and it used to not do this. the tune was dead on and i havent changed anything so i am wondering what is going on, any ideas?
Old 08-21-2010, 07:55 PM
TURBHOE's Avatar
if your locking the tcc at wot you could be loosing the clutch. 900mv is rich and you need a wideband to be sure what its at. but if everything is constant ie: fuel press and afr and timing i bet on the tcc slipping. see if you can log tcc slip. i think i can with hpt.
Old 08-21-2010, 08:18 PM
tallbluslpr's Avatar
Yes my money would also be on the coverter slipping. If you have hp tuners go to the tcc wot table and turn the converter lockup off at wot and see if it goes away. You should really get a wideband consider it a performance upgrade slight changes in afr make a huge differance in power output. Also check your injector duty cycle It shouldnt be over about 80ish %.
Old 08-22-2010, 07:07 AM
Gadgetized's Avatar
More than likely a wastegate or BOV problem.
Old 08-22-2010, 09:28 AM
TURBHOE's Avatar
Do rpm's drop or rise at all during this?
Old 08-22-2010, 11:23 AM
bad cutt's Avatar
rpms dont move thats why i dont think its a tcc problem.
Old 08-22-2010, 12:30 PM
might be too rich. my truck used to do the same thing on the top end when the afr would go to 10.2.
Quick Reply: truck surging
