truck surging
#21
ok i was watching o 2 sensors when i get on it it goes to 900 mv. tcc goes to low duty cycle when i am at wot. it is at 96 percent most of the time though. im not sure i understand how duty cycle works. as far as tcc slip goes it actually goes negative when i get on it.
#22
Are you speed density or MAF? Have you tried it without the meth? I had problems soaking the MAF with meth in boost even though it nozzle was downstream. Problem fixed when I went SD
#25
11 Second Hall Moniter
When I read this, I thought it might be the transmission or TCC slipping. If you're locking the converter on WOT, you may be getting ready to lose the 3-4 clutches and/or the converter clutch. Definately get the wideband on there and check it also, but if that's good to go, your transmission probably isn't.
