Trying to run 17-18psi and driving daily???
Old 02-16-2010, 04:21 PM
EVILGMC's Avatar
the heads will most likely lift or push water at about 15psi
Old 02-16-2010, 04:56 PM
WJ MARK's Avatar
I would stay where you are at with boost, and just add some squeeze to the mix!!
Old 02-17-2010, 07:07 AM
scooter k's Avatar
Talked with Erik at HK engines and he said I will be fine at 18psi. No problems.
Old 02-17-2010, 08:46 AM
LsxCody's Avatar
well good luck with more boost
Old 02-17-2010, 04:59 PM
9 Second Truck Club
tarinitup's Avatar
I would say your fuel system is going to determine how far you go on boost. I'd like to know how far myself since 12lbs feels slow already.
Old 02-17-2010, 07:46 PM
scooter k's Avatar
The meth is supposed to help take the load off fuel pump.
Old 02-17-2010, 10:57 PM
TX Tahoe Z71's Avatar
Go big or go home
Old 02-17-2010, 11:02 PM
WJ MARK's Avatar
and cool that hot air the TVS puts out!
Old 02-17-2010, 11:03 PM
Baltimore Whore
Mangled03gmc's Avatar
Is he going to replace the head gasket if you pop one??? You would def be pushing it at that psi with out studs... If you had them, then it would be very doable..
Old 02-17-2010, 11:58 PM
ONLYA4.8L's Avatar
I recommend arp.. They kept my heads on when I was running 175shot in my lil 4.8l
Quick Reply: Trying to run 17-18psi and driving daily???
