? For tuning a turbo'd 6.0 LQ4/LQ9 with factory ECU
If your initial boost target is 14-18psi you're in for quite a ride. If you plan to run more than 15psi of boost, by all means go to the 3 bar. I just don't like to use the 3 bar unless you really plan to run that boost for sure. You take resolution away from the map sensor every time you add on to it's range.
The pcm in the newer stuff has other tools to make fueling/spark desicions. The IAT, ECT, and barometer readings all have an effect on fueling outside of the MAP/RPM readings. Even in OLSD if you get the correct injector info put in you should always be within a few percent of your commanded AFR without worrying too much about the weather. After all correct hard info is put in you just tune the V.E. table until your wideband readings match your commanded AFR and you should be in good.
I have personally used EFI Live and HPT. Which one you like more is really a toss up. I personally preferr HPT, but EFI Live has given great results also.
Not less accurate, but less fine:
It would be the same as three tape measures. The first one is one foot long, and it has marks every 1/16th of an inch. The second tape is two feet long, but the marks are 1/8 inch apart. The third one, at three feet, has about five marks per inch. They all have about the same number of measuring points, just spread farther apart at longer lengths (Higher boost).
BoostedBowTie
01-03-2020 06:46 PM
FlowmasterMufflers
07-22-2015 01:29 PM
