turbo 4.3 sonoma project.
Old 11-23-2009, 11:06 PM
  #101
f4tal's Avatar
Originally Posted by parish8
28lbs is the exact number i programed in to get my ltrims back in line.
(28x6)x2 = 336fwhp worth of fuel. thats pretty good. add a little meth to it and things will be great.
probably be happy around 10psi. the goal is 300rwhp.
i hope the owner steps up to some drag radials and cal tracs. then later maybe a little more power. if we try and go over 300rwhp i will talk the owner into some larger injectors.
300hp in an s10 would be pretty sweet. especially with a turbo V6 i know alot of guys do swaps but its nice to see guys build the V6 sometimes. kinda unique IMO.
there was a guy on s10forum i think that was running a frount mount with 60lb injectors... idk how it worked out for him its been awhile since i read that thread... get some vids of it man!
Old 11-23-2009, 11:37 PM
  #102
13 Second Truck Club
A Low Dime's Avatar
Where did you pick up the intercooler? Dimensions? How about the silicone boots?
Old 11-24-2009, 06:23 AM
  #103
single digit dreamer
parish8's Avatar
Originally Posted by 53RUSSELL
Hey parish8 i see your g8 made it into this months hot rod mag. for drag week
yeah, i didn't win anything but they liked the car enough to put it in there.
Old 11-24-2009, 06:26 AM
  #104
parish8's Avatar
intercooler was off of ebay, not sure of the dimentions but it is a tight fit. i will see if i can find the info or just go measure it.
silicone stuff comes from siliconeintakes.com
Old 11-26-2009, 02:37 PM
  #105
parish8's Avatar
the project is pretty much done. got the meth line ran, vacuum lines to the meth kit and wg. wireing for the meth kit, wire for the return pump, wire for the wideband, gauge mounted on dash, low meth light done. i ran the output on the lc1 over to the gas tank map sensor. now i can log a/f ratio and who needs gas tank pressure anyways.
just have a couple of little things to take care of. should be test driving it tomorrow and taking it to the dyno soon.
Old 11-26-2009, 02:51 PM
  #106
thunderwagen's Avatar
This is a cool little project. I wish you lived closer. I wouldn't mind doing a setup on the camaro like you did on your G8.
Old 11-27-2009, 07:07 AM
  #107
reiners88's Avatar
cant wait to see what it makes. great job man. as always.
Old 11-27-2009, 03:52 PM
  #108
parish8's Avatar
first test drive. only about 2.5psi and it didn't feel quick at all
not sure what timing to run. it is around 22deg which might be good for this engine. meth is working and pushed the a/f ratio down into the lower 10's.
no issues at all yet and i drove it around for awhile.
going to toss a 6psi spring in there and try it again. lean it out a hair, research where the timing should be... i will report back.
Old 11-27-2009, 04:28 PM
  #109
TURBHOE's Avatar
if you want i can send you a tune that i did for the 4.3l. i think around 22 or so degrees with 13-14psi with no knock and no meth.
Old 11-27-2009, 10:09 PM
  #110
parish8's Avatar
woohoo, it is done. feels pretty good too. a buddy of mine came over and watched the laptop while i drove and everything looks pretty good.
started out at 3psi(23lbs of air or about 230fwhp) and the truck didn't feel too great. no issues, no leaks, not much bumping around but there is a little rumble that i can't locate. the laptop looked good so we swaped out the wg spring to a stronger one and ended up aroud 6psi(29lbs of air or about 290fwhp). ohh yeah, it was starting to feel decent. not crazy fast but not stock anymore. everything looked good so we pushed the boost up to 10psi(36lbs of air or about 360fwhp). feels even better. the airflow numbers indicate around 360 fly wheel hp and i dont doubt it. 1st gear just gets wheel hop. i was waiting till about 30mph and 2nd gear to punch it and it was still breaking loose.
10psi is pleanty for today. now we need to get to the dyno and dial things in. right now the a/f ratio is pretty rich. there is also a hesitation right off of idle that i hope dynotom has an idea for. i can see it going lean but i dont know how to add fuel right there. this is the funest part of the project. working into the power... after it is tuned i am going to use the gtech to set up the shift points. seems like it is shifting too late to me. power if falling off and it is hanging there a little before the shift happens. it is only 5300rpm or so but if that is when it is done i guess that is when it is done.
Quick Reply: turbo 4.3 sonoma project.
