turbo 4.3 sonoma project.
#133
Jim, I am not sure if you should run the oil return pump upside down. The Reverso pump I have says not to. The oil can leak by the shaft seal and contaminate the motor. I would check with the supplier to see if you can run it inverted. The Reverso can be run upright or horizontally.
Nice build!
Nice build!
#135
Nice build!
Nice build!
"The pump will run in any orientation – vertical, horizontal, upside down, and at any angle."
#136
based on that the truck is up 125rwhp and 140rwtq at 8.5psi.
i told the owner about the header wrap and he has some ordered all ready, a am interested to see how much difference it makes. w wont have any dyno numbers or anything like that.
he also has some caltracs on the way.
#140
Ya, both HPT and EFILive support the I5's in the Colorado's. I've been trying to talk my brother into turboing his 07 cc4x4 CO, There not great on gas and don't really have much power, so would be perfect for them, and with the way the motor is setup, would be EASY!
