turbo 4.3 sonoma project.
Old 10-17-2009, 07:43 PM
  #61
single digit dreamer
parish8's Avatar
pretty much right there where you have that gauge.
Old 10-18-2009, 06:21 AM
  #62
TURBHOE's Avatar
on our build we had to weld a bead around the top outside edge of the throttle body to keep the chrage pipe on. around 10psi or so it was blow off no matter how tight we got it.
Old 10-18-2009, 10:09 AM
  #63
parish8's Avatar
yeah, i figured. i am either going to run an ls1 tb or cut off the snout of the new tb i get with the intake and weld that on to the old one.
Old 10-28-2009, 07:15 AM
  #64
reiners88's Avatar
ive been reading the whole thread and now im thinking about going turbo on my S10. its a 96 4.3 auto. pretty much the same truck parish is building. i want to wait a little while and see how well the setup works. plus save up some money lol. Im actually a new guy on here and wanted to step into the light a little.
Old 11-03-2009, 07:42 PM
  #65
1st_TACO's Avatar
looked like you are still running a MAF on this truck. are you gonna have to use a signal clamp on it or...??? will it keep up with your 300rwhp goal?
Old 11-03-2009, 08:01 PM
  #66
parish8's Avatar
not sure. i figured it would handle 300rwhp but maybe it wont. if not there are ways around that. i always thought parallel paths one with the maf and one without would be an easy fix for stuff like this.
Old 11-03-2009, 08:06 PM
  #67
1st_TACO's Avatar
i was thinking without.... and i am a little biased too, i personally have never been a fan of a blow thru maf set up. but its your world and im sure it will turn out just fine. good luck
Old 11-04-2009, 06:44 AM
  #68
TURBHOE's Avatar
that year sonoma you could do 2bar sd with hptuners...... if you wanted to.
Old 11-04-2009, 04:08 PM
  #69
parish8's Avatar
we will probably do that IF the maf maxes out. i would be suprized if the maf maxed at only 300rwhp.
Old 11-04-2009, 05:33 PM
  #70
WJ MARK's Avatar
Im probably one of the few that still uses a MAF. Mine still works for over 500whp.
Quick Reply: turbo 4.3 sonoma project.
