Turbo 4.3L - carburated-
i am thinking about pickin up a first gen s10 and putting a carburated 4.3L in the beast. i was thinking a built 700r4 or th350 with a ford 8.8" rearend but catch is- 3000rpm stall
CSU 750 blow through carb
edelbrock 2114 intake manifold
270ah cam (turbo freindly)
lower the compression to 9:1 or a little lower
96+ vortec heads w/ port and valve job along with new springs bowl work
Double roller timing chain
SRP pistons w/ eagle rods- ALL ARP hardware w/ cryfreezed bottom end and crank
now- Single T-60 or T-70 turbo on a blow through set-up- look for 500whp- it would be a fun ride on some 11" wide wheels out back with nitto 555r's
-----------------------QUESTIONS--------------------
on a blow through carb how does it know when to keep adding more fuel as the boost pressure rises.?
Would a t-60 or T-70 be more suitable for my application? i see 3litre supras running t-70's.........
DO they make an aftermarket electronic overdrive for the th350?
Is a 350 cheaper to build than a 4.3L???? i have heard this....
More pressure equals more airflow equals more power, to a point.
The increased airflow will be "read" by the carb and more fuel is added automatically.
See this for turbo selection: http://www.forcedinductions.com/help.htm
Gear vendors overdrive for the TH350.
350 is much cheaper than the 4.3L. But you can be different and do the V6.
Former Vendor
Ricky
lxcoupe
09-06-2017 08:24 AM
TXjeepTJ
09-11-2015 12:23 PM
hirdlej
08-27-2015 10:22 PM
270ah, 43, 43l, blow, build, cam, carb, carbed, carberated, carburated, carburetor, performance, silverado, thro, turbo
