Turbo a 5.0 Mercruiser
Old 02-25-2009, 10:29 PM
Baltimore Whore
Mangled03gmc's Avatar
Yah my mistake on the MPG, not to start a pissing match with ya on the mph it will go, but not 55 with 220 hp srry. Tech it should be knots which is about 1.2 mph for 1 knot.. The bridge thing isn't a legit way to declare the speed..And the water pickup speedo is garbage. I would look into a nice exhaust setup for it from eddie marine, a new intake manifold. With it being a 96 it is still a carbed motor correct.. Thats where I would start.. You going to spend just as much on a turbo or blower set up as you will build a nice healthy small block for it... Also a alpha will hold hp in a lighter boat, I am putting 400+hp through one in my 202 stinger, just have to be smart and don't pull hole shots..
Old 02-25-2009, 10:32 PM
Ender06's Avatar
Originally Posted by Wilde Racing
, but the Alpha cant handle too much more power.
That would be great, I'd like to know what it would handle
Old 02-26-2009, 06:35 AM
LS1Tech Sponsor
hellbents10's Avatar
I wouldn't put more then 300hp in front of the alpha. For $2200.00 I can sell you a 350/270hp freshened long block right now.
Old 02-26-2009, 07:55 AM
gdev_'s Avatar
Hellbent is right. 300 HP is the most suggested for an Alpha.
Old 02-26-2009, 12:05 PM
duwem's Avatar
You need 2 blowers:
http://www.mercuryracing.com/sterndrives/
These engines are sexy, carbon fiber valve covers, chrome, anodized an fittings....
Old 02-26-2009, 12:12 PM
How do I change this text
Wilde Racing's Avatar
Alpha 1 is rated for 300hp
Bravo 1 is rated for 400hp (including X)
Bravo 2 is rated for 450hp (Including x)
Bravo 3 is rated for 400hp
Bravo 3x is rated for 450hp
Bravo 1 XR is rated for 600hp (includes sport)
Bravo 3 XR is rated for 525
Old 02-26-2009, 12:14 PM
The biggest engine is a 1200hp 557cid 8:1 compression, twin blown fuel injected engine.
Old 02-26-2009, 12:38 PM
LS1Tech Sponsor
We like number 6's around here! I think out shop has about 20+ right now on boats hahaha!
Old 02-26-2009, 02:27 PM
blownerator
BlownChevy's Avatar
Unless you are running a cat, twin 520ci blown big blocks, and surface piercing drives you are a *****.
Old 02-26-2009, 02:48 PM
Baltimore Whore
Talking
LMAO yah the freaking drives cost more then 2 of them boats combined.. 6's are bad bitches.... Arnesons are just indestructale Back on the topic of the alpha, you can run more then 300 through them with out problem IN A LIGHT BOAT.. Look at all the older performance boats(28 ft range) that came with twin BBC and alphas. Same with the bravos, I know a dozen guys putting 700 hp to them, including us when we finish our build.. Its all about driving the boat, having common sense... If you wanted to upgrade drives with out have to redo inner plates try to find a SS alpha drive(good luck) they were rated for more hp over the stock alpha, had bigger internals, shaft... Give MEL RIGGS a call...
AND FOR THE GUYS WHO WANT FAST GET OUT YOUR CHECK BOOKS
http://turbinemarine.com/ FTMFW
Quick Reply: Turbo a 5.0 Mercruiser
