Turbo 6.2
Old 08-27-2012, 07:06 PM
  #41
Performance Trucks Sponsor
FarmTruc's Avatar
keep in mind these new pcm's and 6.2L's are picky, some of them just don't like timing; and others do.
Old 08-27-2012, 10:38 PM
  #42
9 Second Club
Originally Posted by Boober
Not to thread-jack but what are you flex fuel/returnless fuel system guys doing about low fuel pressure on boost? Why am I the only one trying to find a simple solution to this problem? My fuel pressure goes into the mid 30's when I'm WOT at about 8psi. I'm installing a Kenne Bell BAP tomorrow but I'm sceptical that it will help because it's for a 5th gen Camaro and I'm not even sure the fuel pump control module works similar in my truck. The only other solution it seems is to go full return style.
If your goal is 500whp and you dont have any plans to change your fuel system, you WILL lean out/ max IDC at WOT with the boost your planning to run.
I'm running a stock flex fuel setup for now. With FAST 85lb injectors.
That video was WOT.
Old 08-28-2012, 06:49 AM
  #43
Boober's Avatar
That video was WOT.
Do you have a scanner? What are your injector duty cycles, or your rail pressure reading at WOT? I have 60lb injectors but they only flow about 45lb/hr at WOT. The injectors are NOT the bottleneck. You could put 160lb injectors in and the pump will still deliver the same amount of fuel.
Old 08-28-2012, 08:17 AM
  #44
that was awfully slow for wot. You should really take the advice and go with a bigger turbo. I think a S475 with a 87 wheel would do wonders with that 6.2. With that turbo on the same boost I can almost guarantee you will see 100 more hp. And you will have the capablility of turning it up and make some real power. As long as your fuel system is up to par and you have good springs. The meth kit and bigger intercooler are nice but for the same money spent on that you couldve gotten the correct size turbo and be way better off
Old 08-28-2012, 08:26 AM
  #45
10 Second Club
GONEB4U's Avatar
Dude I don't want to sound like an *** but if that's wot then you better get a bigger turbo. My old 6.2 Sierra Denali ran like that with headers,exhaust and a tune. Heck your starting from 60 in your vid. I currently have a Trick Stage 3 with a 76mm .96 at on my 6.0 L76 Vmax Silverado running only 2lbs of boost cause the wastegate spring is weak (new 7lb spring on order from turbosmart) that will eat your truck. Listen to the masses. Get a bigger ar. exhaust housing or just a bigger overall turbo.
Old 08-28-2012, 02:00 PM
  #46
9 Second Club
I was running 45 not 60, and I did roll into at first so it wouldn't downshift. Take a look at this 0-60 video.
I haven't completely decided against going to a larger turbo, but I'm going to put in the larger intercooler which I already have, and put in the Alky Control kit that I already have as well. Once this is done I'll retune it myself, and put more timing into the truck and see how it feels. I like how quickly this turbo spools, I just might be satisfied with a little more up top. I'm going to LS Fest with this truck, and I'll be towing my Corvette so I'm curious to see how it does towing ( which is important to me ). While I'm there I think I'll run it down the track and see what it does. Then I can make an educated guess at what it's putting to the ground.
Old 08-28-2012, 02:20 PM
  #47
Llaverito's Avatar
Damn that looks slow, I have a 07 2500Hd 4dr 4x4 that i pulled out its tired ly6 and went to a stock 5.3, everything is stock except for bigger injectors. My hd pulls damn hard for being a 5.3 in a heavy tank and runing 10psi with no meth or anything. It has the stock exhaust with an added magnaflow bullet to keep it real quiet. Its also running on 33s
Old 08-29-2012, 08:08 AM
  #48
Truck Sponsor
TrickTurbo's Avatar
Hard to tell but looks to be around 6-7 seconds 0-60
not bad for a heavy awd truck with 24's. Even at 8 it isn't bad.
What's the truck weigh in at with driver and passenger?
5k-6k- more??
I think once the tune is corrected (fixed) you'll be fine. For a stock truck the a turbo added stock cam stock muffler system nothing bad there.
Once the cam and 2nd turbo go on it will be more.
Old 08-29-2012, 10:04 AM
  #49
9 Second Club
5k-6k- more??
It is hard to tell, but I think It's closer to 6 seconds. The truck is completely stock even the stock exhaust, and it's on the heavy side for sure being Crew Cab AWD, and running 24's. The truck is also running off the gate with a 6.9# spring. I think that's why the boost looks to be falling off up top because the wastegate is bleeding off the pressure trying to bring it down some. That's my fault since I have a boost controller that needs dialing in. Outright speed and power were not the absolute goal here. There's more on the table, and I need to finish optimizing the combo, but I'm pretty confident it will meet my goals once the tune and minor details are worked out. If that doesn't work out I'll go to a bigger turbo.
subeone
09-16-2015 03:45 PM
806primer69
08-28-2015 08:07 PM
05GMC4.8
08-07-2015 09:55 PM
rudvirus
08-05-2015 08:05 PM
Ls3silverado
07-31-2015 04:22 PM
Quick Reply: Turbo 6.2
